New PCB isolation milling software (beta verison)
Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: New PCB isolation milling software (beta verison)
    dubble
    Guest
    Smile New PCB isolation milling software (beta verison)
    Hi everybody,
    I've developed a software recently which generates milling path from Gerber files for isolation PCB milling.
    The software is Beta version and probably will remains beta for a while, because at the moment I don't have time to further work on this project.
    Because the software is a freeware and it is beta, it may contains bugs, so everybody should use it on his own responsibility.
    I just liked to let you know that this software was released and that you may used it: http://cncdrive.com/Software/PCBMill.zip
    The software is freeware and anybody may use it for any purpose.
    I hope that you guys out there who are using your machines for hobby or for running your small businesses will find this software useful!
    Cheers,
    Balazs
    Registered Burnit0017's Avatar
    Nov 2009
    Greetings , I am new to milling pcb's. I am currently using PCBxpress to create the pcb layout, print the layout, export the layout as a .dxf file. The .dxf only exports the hole locations. Then I use TurboCad to redraw the traces. Then I use LazyCam to generate the G code.
    What is Gerber file and is there any freeware that creates it?
    dubble
    Guest
    Gerber is an industry standard file format for PCB manufacturing.
    Most of PCB designer softwares can generate gerber files from the PCB file
    and all PCB manufacturers using Gerber files to fabricate PCBs.
    You may read more about Gerber files forexample here:
    http://en.wikipedia.org/wiki/Gerber_File
    Nov 2009
    Greetings, Thanks for the heads up. I was able to download and install your software. It looks easy to use. I am trying to drill holes in the PCB, but I keep braking bits. Can you suggest spindle speed and plunge rate? Thanks again and best regards.
    dubble
    Guest
    I advice to set the spindle to the highest possible RPM.
    You know on industrial PCB drilling machines there are air spindles with really high over 50k RPM.
    Probably you don't have an air spindle at home, but a 20-30k RPM would be good to have.
    What diameter of holes are you drilling?
    In general if the drill bit has low diameter, the machine construction should be robust and vibration free, because a small buckling of the Z axis may break the drillbit.
    Also too low feedrate of the drilling in the material may cause a burning and damage of your tool and a too high feedrate may also damage the tool, so try to find the midway.
    Dec 2004
    Memphis, TN
    Burnit,
    I drill at 5 IPM with success. These are carbide PCB drills made for FR4 and epoxy. I usually drill at 18K RPM.
    FWIW,
    Jay
  7. #7
    Registered Drools's Avatar
    Feb 2009
    Ditto whay Jay said.
  8. #8
    dubble
    Guest
    Wink
    Hi guys,
    I made some printscreens from pcbmill generated milling path.
    See pictures:
    Some zooming to see the tool-offset:
    BR,
    Balazs
  9. #9
    Oct 2005
    Quote Originally Posted by Burnit0017 View Post
    I saw your photos in the other PCB thread Burnit, looks like you have really bad runout of your spindle. That would be the cause of the broken drills.
  10. #10
    Registered Jesse B's Avatar
    Aug 2009
    Just installed it and took a peek. Looks pretty good, nice and simple.
    Just wondering, what language did you program it in? It looks like VB to me, but I'm unsure (haven't used anything else in Visual Studio which it looks like it came from).
    Thanks,
    - Jesse
  11. #11
    Nov 2009
    Question Requesting help
    Greetings, I using TinyCad and Freepcb to create a Greber file and I receive a Unhandled exception error stating that StartIndex cannot be less than zero is there a solution to this problem?
  12. #12
    Sep 2006
    romania
    Quote Originally Posted by dubble View Post
    Hi everybody,
    Cheers,
    Balazs
    Please, see the attached pictures:
    - exported bottom pads and vias layers from an Eagle PCB.
    - your software is not displaying well all the pads
    - free online gerber viewer is showing board ok
    But I think is a great idea to make a gerber-to-gcode converter!
    Attached Thumbnails Attached Thumbnails New PCB isolation milling software (beta verison)-cncdrive-png   New PCB isolation milling software (beta verison)-free_online_gerber-png
    Attached Files Attached Files
  13. #13
    Jul 2010
    indonesia
    Talking
    thank you all...
    but i have some quest.
    can i use the output G-code of PCBMILL at EMC2..???
  14. #14
    dubble
    Guest
    Quote Originally Posted by eSilviu View Post
    eSilviu,
    I think that your pads have a hexagonal shape, this is yet not supported in the PCBMill. You should get warnings about it while the contour is generated. Unknown and not supported aparture shapes are ignored by the software, that's why some pads not translated and not shown at all. If you like to get a correct code from PCBMill, change the pads shape to circle or oval.
    Probably later I will add some more apartures, but now I have no time to work on it unfortunately....
    Cheers,
    Balazs
  15. #15
    dubble
    Guest
    Quote Originally Posted by tyo View Post
    thank you all...
    Yes and you may customise the output codes in the "settings" menu if needed.
  16. #16
    dubble
    Guest
    Quote Originally Posted by Jesse B View Post
    Thanks,
    C# and unmanaged C++
  17. #17
    Sep 2011
    Hk
    Is PCBMill still supported? I have V1.0 (seems to be latest and only one).
    It makes some errors though. Screenshot and G-Code attached.
    The screenshot shows the original Gerber left, and in blue the output from PCBMill.
    Attached Thumbnails Attached Thumbnails New PCB isolation milling software (beta verison)-iso-jpg   New PCB isolation milling software (beta verison)-code-pdf
  18. #18
    dubble
    Guest
    Hi Yello,
    No, there is no new version.
    And PCBMill was never supported. It is a free software, downloadable "as it is".
  19. #19
    Sep 2011
    Hk
    Well then, I installed Line Grinder. It converts nicely.
    Of Itself So - Line Grinder, Gerber to GCode Isolation Milling
  20. #20
    dubble
    Guest
    Great. Thanks for the info.
