Leadshine L7 servo drive error
Results 1 to 3 of 3
Thread: Leadshine L7 servo drive error
    Pnai's Avatar
    Nov 2024
    Default Leadshine L7 servo drive error
    Hello all.
    This is my first post in this forum , I don't know if this is the right section to post.
    I'm running a Large Format UV Print and I'm have problem with the Double Y's axis.( Position Error ).
    I search for the the L7 drive to Log test and I followed all the steps , When I press run it display error , although before I run the log test it gives ready ( r 0 ).
    I will write the steps I make for Log test if it help:
    (SET): d015P
    (MODE): PR000
    (MODE): RFJ0g
    (SET): Jog-
    (?): error
    I hope someone can help me .
    Thanks a lot
    Member cncmakers001's Avatar
    Jul 2011
    China
    Default Re: Leadshine L7 servo drive error
    Quote Originally Posted by Pnai View Post
    Hello all.
    (SET): d015P
    (MODE): PR000
    (MODE): RFJ0g
    (SET): Jog-
    (?): error
    Thanks a lot
    Make sure all cables and connections are secure.
    Sometimes a loose wire can cause a position error.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Pnai's Avatar
    Nov 2024
    Thank you for your reply.
    I checked evey single wire and tested it with multimeter all limit and emergency sensors working good
