Material Machining Solutions
Page 1 of 37 123411 ... LastLast
Threads 1 to 20 of 733
Forum: Material Machining Solutions
Discuss general material machining problems and solutions here.
  1. General discussion on tolerances
    Started by Dominic1649‎, 07-11-2024 01:52 PM
    cnc machining, materials, tolerances
    10-30-2024, 07:37 AM Go to last post
  2. Exclamation Need Help!- MDF Shaker style doors look terrible
    Started by ShorelineCNC‎, 06-17-2024 11:29 AM
    06-19-2024, 04:16 AM Go to last post
  3. punching rubber
    Started by subnetgate‎, 11-29-2023 04:10 PM
    11-29-2023, 07:43 PM Go to last post
  4. Struggling to break chips while turning 4130.
    Started by rbeachner‎, 10-06-2023 03:59 AM
    10-17-2023, 04:34 AM Go to last post
  5. Problem- Tip of endmills keep chipping
    Started by Hyudryu‎, 07-01-2023 06:59 PM
    6mm, cnc, end, flute, holes
    09-11-2023, 07:48 PM Go to last post
  6. some questions about 6al-4v
    Started by QuinnSjoblom‎, 05-06-2023 05:39 PM
    direction, find, grain, parts, titanium
    05-08-2023, 05:45 PM Go to last post
  7. Moved: Need Help!- machine handling
    Started by mikey B‎, 06-06-2022 11:07 AM
  8. Cool Newbie- How does water cut things but it is so soft. Mohs question.
    Started by ballsystemlord‎, 03-16-2022 08:57 PM
    cut, instances, mohs, scratch, water
    03-17-2022, 12:27 AM Go to last post
  9. Choosing material for a shift fork
    Started by Paraquat‎, 03-02-2022 01:13 PM
    aluminum, fork, machinist, shift, silicon
    03-16-2022, 11:30 AM Go to last post
  10. Price for Alloy Recycling
    Started by boydage‎, 02-24-2022 12:42 AM
    alloy, surprised, fact, $1.40kg, sm-n970f
    03-02-2022, 02:09 PM Go to last post
  11. Nickel Boron Coating for Firearm
    Started by K9guy‎, 07-13-2021 07:52 PM
    07-13-2021, 07:52 PM Go to last post
  12. Need Help!- Maraging 350 Ni/Cr./Co
    Started by Michael82‎, 04-12-2021 04:55 PM
    cut, inserts, maraging, material, stuff
    04-12-2021, 04:55 PM Go to last post
  13. alternative to scotchbrite exl wheels
    Started by metalmayhem‎, 04-10-2021 05:52 PM
    alternative, exl, expectations, low, worse
    04-10-2021, 05:52 PM Go to last post
  14. PaperStone
    Started by cpnagle_cnc‎, 01-26-2021 04:54 PM
    03-12-2021, 11:19 AM Go to last post
    01-15-2021, 05:45 PM Go to last post
  15. DURALCAN
    Started by MichalTA‎, 10-27-2020 07:33 AM
    10-27-2020, 07:33 AM Go to last post
  16. Coating for insert holders
    Started by flick‎, 04-22-2018 10:36 PM
    coating, corrosion, holders, insert, invincible
    10-13-2020, 08:37 AM Go to last post
  17. Need help with material choice
    Started by Hydrops‎, 05-30-2020 08:49 AM
    09-08-2020, 03:34 AM Go to last post
  18. S/F - Small holes in mild steel.
    Started by Wtz-44‎, 06-25-2020 03:53 AM
    06-25-2020, 12:30 PM Go to last post
  19. Talking Has anyone used FIBEROCK
    Started by rfjr88‎, 06-11-2020 04:04 PM
    bits, feed, fiberock, material, order
    06-11-2020, 04:04 PM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 6 users browsing this forum. (0 members & 6 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
