Machines running Mach Software
Page 1 of 43 123411 ... LastLast
Threads 1 to 20 of 852
Forum: Machines running Mach Software
Discuss your set-up and experiences running your machine using Mach software here.
  1. Newbie- Question about Ports with Smooth Stepper Board
    Started by Swh05‎, 01-23-2024 10:39 AM
    board, cnc, port, smooth, stepper
    03-20-2024, 05:28 AM Go to last post
  2. UC100 and Spindle speed off
    Started by ny_racer_xxx‎, 02-14-2024 07:52 PM
    02-15-2024, 07:01 PM Go to last post
  3. Spindle Relay on an Ebay 5axis Breakout Board
    Started by xuraax‎, 07-22-2023 06:48 AM
    5axis bob, issue, power, relay, spindle relay
    01-29-2024, 03:30 PM Go to last post
  4. motor direction in Mach 3
    Started by sndpntlynch‎, 04-18-2011 07:04 PM
    since
    12-31-2023, 11:54 PM Go to last post
    12-11-2023, 06:19 AM Go to last post
  5. Unhappy uc100 usb motion controller and Windows 11
    Started by tulsaturbo‎, 10-14-2023 03:43 PM
    controller, motion, uc100, usb, windows
    10-14-2023, 03:43 PM Go to last post
  6. Need Help!- missing steps on the circular path
    Started by blazo‎, 06-04-2023 11:18 AM
    06-09-2023, 05:02 AM Go to last post
  7. Question mach3 Digital Read Out Jumping/Bouncing
    Started by bradles‎, 04-16-2023 08:53 PM
    digital, issues, mach3, machine, moving
    04-17-2023, 05:34 PM Go to last post
  8. Mach3, ESS, & Spindle Motor Tuning
    Started by kolias‎, 01-01-2023 06:43 PM
    change, motor, parameters, spindle, tuning
    01-02-2023, 03:49 PM Go to last post
  9. BL-USBMACH-WS-3.25 Output not working
    Started by cusna‎, 10-26-2021 06:05 AM
    12-02-2022, 11:28 AM Go to last post
  10. Ref All Home, Slaved axis does not synch.
    Started by hkinkade‎, 11-01-2022 05:08 PM
    axis, home, jog, ref, slave
    11-01-2022, 05:08 PM Go to last post
  11. Jerky Axis Moves on Curves
    Started by kolias‎, 10-17-2022 04:26 AM
    cnc, curves, jerky, lines, straight
    10-17-2022, 07:13 PM Go to last post
  12. Need Help!- Mach4 v 4809
    Started by edcross‎, 07-14-2022 08:33 AM
    controller, ess, gecko, mach4, smoothstepper
    07-14-2022, 06:35 PM Go to last post
  13. Question Connecting an Electronic type kinematic Probe
    Started by kawazuki‎, 07-14-2022 09:36 AM
    07-14-2022, 09:36 AM Go to last post
  14. Mitsubishi AC Servo Spindle Retrofit
    Started by jlmccuan‎, 04-04-2022 09:26 AM
    2 Pages
    1 2
    05-18-2022, 05:45 PM Go to last post
  15. Problem- Using Mach3 to keep spindle from cutting my fingers off
    Started by Igloomason‎, 04-16-2022 10:47 AM
    pin, pins, safety, spindle, superpid
    04-16-2022, 01:25 PM Go to last post
  16. mach 3 settings help
    Started by MrAbrasive‎, 04-06-2022 06:14 PM
    c41, control, software, speed, spindle
    04-07-2022, 11:05 AM Go to last post
  17. Need Help!- Cannot move any Axis
    Started by zappafan1‎, 03-27-2022 01:37 PM
    add-in, card, cnc, gecko, purchased
    03-28-2022, 06:59 PM Go to last post
  18. replaced my x/p machine with another x/p
    Started by kjl-pdx‎, 03-12-2022 08:41 PM
    cnc, mach3, machine, x/p, years
    03-12-2022, 08:41 PM Go to last post
  19. New Machine Build- Slave axis is not synchronized with master
    Started by Antrac1t‎, 12-29-2015 02:12 PM
    axis, master, motor, slave, stepper
    02-07-2022, 10:50 AM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 8 users browsing this forum. (0 members & 8 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
