- Haas 3038t rev H I/O board repair help
Hello,
Our Haas VF6 chip conveyor, TSC system and coolant system has stopped working after a short happened at the X axis motor wires. After fixing the motor wires, i noticed some resistors near the aforementioned systems mosfet burned on the I/O board. I will try to fix the board by replacing those burned resistors. The problem i have is i cannot find a schematic or a good picture of the board online so that i can identify value of the resistors.I am kindly asking if someone could provide a schematic of the board or even pictures of the said resistors. I will upload pictures showing the locations and names of the resistors on the board.
The resistors are : R231, R36, R32, R30, R106, R107
Thank you,
Paul.
- You may not post replies
- You may not edit your posts
Forum Rules
