What MW laser to mark stainless steel?
Results 1 to 2 of 2
Thread: What MW laser to mark stainless steel?
    mclaserman's Avatar
    Dec 2019
    Question What MW laser to mark stainless steel?
    I am new to laser cutting and am looking to mark/engrave a QR code onto food grade stainless steel. I want the QR code to be black on the surface so it is easy to scan/have contrast against the metal. How powerful of a laser would I need to accomplish this? Is a laser even the best option for this? Thanks.
    Member keyencelaser's Avatar
    Dec 2019
    Default Re: What MW laser to mark stainless steel?
    Quote Originally Posted by mclaserman View Post
    starts at 45seconds 0:45 OR
    what you need is 10W - 25W usually doesn’t matter if the laser will be industrial grade made for working in dusty harsh environment, so the contaminant and dust particles will not get into marking head and inside onto mirrors. Example you can get https://www.ebay.com/itm/323939974238 for under 10G now, what used to be 65G https://www.radwell.com/en-US/Buy/KE...CORP/MD-H9800W
    and it will do this for you, resolution of the marking is 5um what is 10 times higher from any marker made in China and sold for the same price range or even below 20G. Thank you.
