error 368 (Z axis serial data error (INT))
Results 1 to 1 of 1
Thread: error 368 (Z axis serial data error (INT))
    Member Mohammad1995's Avatar
    Jul 2024
    Default error 368 (Z axis serial data error (INT))
    hello I have a CNC milling machine with Fanuc-mate MB control, recently error 368 (Z axis serial data error (INT)) comes in it, which is always fix in this and sometimes error 368 (Y axis serial data error (INT)) and (X axis serial data error (INT)), which is related. Can anyone help?
    Member bravernoe's Avatar
    May 2024
    Default Re: error 368 (Z axis serial data error (INT))
    Error 368 on a Fanuc control system, indicating "Serial Data Error (INT)" for the Z, Y, or X axis, typically points to communication problems between the control and the servo amplifier or motor encoder. I would suggest checking up the wiring.
    Jul 2024
    I checked all the voltage and connection in the wires and the health of the cables and the servo motor and the power supply, but I did not get any results
