Take a look at 3201 bit #6.
Fanuc Series 0i MODEL F Plus Parameter Manual_B-64700EN_01
https://drive.google.com/file/d/1JUd...usp=drive_link
Hello.
I have done this same setup on older controls (21 for example) and now I am trying the same on a very recent oi-TD.
Using a null model cable and setting up the serial transmission of a simple program, I place the control on receive mode. In this case the INPUT word is blinking - on older controls it was shown LSK.
Then I send the program from the PC.
Program content ends with the % character and a new line.
Now the issue:
While on older controls, when the program ends, the control automatically leaves the "receive mode" and shows the program on "edit mode", on this control it never leaves the INPUT blinking and when I press CANCEL I can observe that the program was correctly received (on first attempts I was thinking that nothing was received) but in fact it was correctly received.
Not sure if some parameter needs to be changed or the "end of file" content should be other so that the control acknowledges that indeed the program transfer ended.
Advice is welcome. Changing the cable is not a very good option as the client is remote (another country).
Thank you
"Teach the ignorant, care for the dumb, punish the stupid."
Thank you. I will ask for bit #6 to be changed to 0.
I will reply if this fixed the issue.
My program ends in:
M30
so this is probably helpful. Thank you
Good morning.
This parameter, bit #6 (NPE) was already set as 0, so, unfortunately the proposed solution did not worked on this case.
Good morning. There is no other possible solution?
No one here that uses the same controller and serial port transfer?
I am still on the same spot as I was.
Thank you
Thank you for the answer.
You suggest that the PMCCNF it set to OFFLINE or similar? I am not near the machine so I do not know what to say to the end customer.
Thank you
The current settings are attached (image) I hope this is the menu that you are referring to, but I do not find the related setting.
Thank you for your time.
on that window press the right + and go on untill you will find a menu called ONLINE
Check there if is in OFF STATE or NOT USE
Thank you for your information.
I have tested and the setting was on USE mode. I tested also in NOT USE and the result was the same.
I have attached the menu where the setting was changed. Maybe something can be observed that might indicate something wrong.
I also included the file input being used. The INPUT word is blinking during the transmission and stays forever blinking until the user presses the CANCEL button.
Last image is how the program ends, that I think is correct.
did the program enetred in CNC memory folder?
what software do you use to transfer programs?
can you show the parameter 3201?
thank you
Yes program is completely received on the CNC.
Code is sent by my own software (that works ok on several other machines, using a null modem cable, as this one)
Parameter 3201 is currently set as:
0 0 0 0 0 1 0 0
Make the parameter 3201 as:
01000000
Once again thank you for the answer.
But from what I read, set #6 to 1 will mean that the program is assumed to be NOT completed when M02, M30 or M99 is found.
Would not this what we wanted to happen?
Thank you.
I asked that to be tested. My customer is in a different continent and is late there already.
When I know the results, I will inform.
Thank you
