- 8ca0 error pls help
8ca0 error pls help
N76 8CA0 Reference signal or line number V faulty)
Module: Q:/commonTNC/sources/regel/dsperror.cpp
Line:328
Process: REGEL
Thread: DSPCLIENT
Errno : 2
Press the END key if you want to reboot the controll
Can anybody clear this for me ,this is the only machining center in my shop and the main machine ,and as it usually goes it makes problems when you are in a tight spot!!
- You may not post replies
- You may not edit your posts
Forum Rules
