- double recheck on sub - M20
hi
just wanting to rechuck a part on the sub to support a part,
i have turned it down and done a support pickup to 40mm on the part to turn the rest down with milling using G750 already,
now i want to unchuck it and move sub Z down the part further and rechuck on it. want to move along to chuck 80mm of the part now.
whats the best way to move sub along the part more so i can better support for cut off?
will a simple $3 , open chuchk, command a Z move to z80, close chuck?
will the main spindle Z stay put?
thanks, rob
- You may not post replies
- You may not edit your posts
Forum Rules
