Hello, i have just setted up the table CNC wood router machine , now i want to add the home made vacuum table. Now i am wondering what power of the vacuum pump should i use, since the clumping area is 480x490(thats also the size of the vacuum table i would create so it would fit through all clamping area). The spinde i am using is HITECO S.13/18 24 ER25 DX BT , which has a maximum of 24000 RPM and has a power of 220/380V.The plan is vacuum table to vacuum down maximum hight of 30mm wood. Thanks in advance for all the suggestion you will provide about the vacuum pump i should use, also would really appreciate if you have any other suggestions on what i need to be careful.
