Old 11-06-2009, 03:25 AM
aviatorskate's Avatar
aviatorskate aviatorskate is offline
aviatorskate is on a distinguished road
Proper Router tools
I will be using a 1/4 trim router for my machine.
What type of cutters are recommended for the following?
Wood (small signs or 2d stuff)
Plastic (small panels for flightsim project, with small letters)
Metal (thin aluminum pieces)
Craig
Old 11-06-2009, 11:13 AM
beone beone is offline
beone is on a distinguished road
I have gotten to where I do most of my work with an engraving bit--1/4 in carbide. Works well in wood or plexi with proper speeds. then I use a 1/4 or 1/8 spiral upcut carbide for any flat areas. This does about 95% of my carving. I do a lot of plaques in oak and foundry patterns in wax and tooling board. I just got the tooling board (48 psf). Boy is it great! but expensive!
In the words of the Toolman--If you didn't make it yourself, it's not really yours!
Remember- done beats perfect every time!!
Old 11-06-2009, 12:57 PM
706jim 706jim is offline
706jim is on a distinguished road
Craig
We use negative helix HSS mills for routing thin sheet aluminum. The negative helix prevents the metal from lifting up as it is cut.
Example: 8000rpm 40 in/min feed with 1/4 cutter 0.032 "O" condition 2024 aluminum.
Any info on a Digital Tools CNC Router? xscsime Ability Systems - LPT Indexer and G-Code 10 06-30-2009 11:32 AM
Any info on a Digital Tools CNC Router? xscsime Commercial CNC Wood Routers 0 10-29-2007 10:05 PM
Real machine tools on router? rustamd DIY-CNC Router Table Machines 4 06-09-2007 12:38 AM
Router Tools for liteply and balsa planekrazie DIY-CNC Router Table Machines 4 01-19-2007 11:44 PM
