Old 11-05-2009, 11:07 PM
tcj2219 tcj2219 is offline
tcj2219 is on a distinguished road
Help with best machining process?
Hello,
Would someone be able to advise what machining process would have been used to machine this aluminum instrument housing? From the attached image it appears that it may have been manufactured in a turning process? If so, how are the mounting ears cut? Before or after the turning of the housing?
One last question if I may? The front has a small threaded ring that secures the front glass to the housing. How would this small threaded ring be manufactured?
I am trying to duplicate the housing if possible, and not sure the best machining method? Instrument is late 1930's vintage if this helps. I have little metal working experience, sorry if this is a stupid question.
Thank you in advance for your reply.
Regards, Troy
Old 11-05-2009, 11:18 PM
Geof Geof is offline
It was probably diecast and then the body turned on a lathe and the thread for the ring on the front also done on a lathe; in this case the 'ears' would be cast not cut.
Duplicating the shape precisely may be quite a challenge but if a square front with just corners radiused is okay it could be done on a CNC milling machine from a block of aluminum.
Old 11-06-2009, 10:00 AM
SORCHEROR SORCHEROR is offline
SORCHEROR is on a distinguished road
that part could be done in a new modern cnc lathe with live tooling,but back than im sure it was cast and machined,you could cut it in a cnc mill if you have one
the part looks like its turned even on the ears,maybe a screw machine did them with cam followers,i would bet on it
Old 11-06-2009, 05:34 PM
eartaker's Avatar
eartaker eartaker is online now
eartaker is on a distinguished road
This piece would not be hard to replicate. The inner housing could be made on a Lathe and the treads could also be turned. The ears could easily be cut on a CNC mill with ease. Its all in the programming.
Old 11-09-2009, 11:04 AM
will gilmore will gilmore is offline
will gilmore is on a distinguished road
You could do the entire thing on a cnc mill and thread mill the threaded parts. If you are just making 1 or 2 you could do it on a manual mill and lathe using a boring bar or similar on the mill to cut the curved shapes in the ears and filing to finish.
Problem- Process controls for Precision Machining mthompson General Metalwork Discussion 1 10-26-2008 05:09 PM
design and machining process project5k Mechanical Calculations/Engineering Design 17 08-07-2007 10:16 AM
In the process Smitty911 Dolphin CADCAM 5 05-10-2007 01:34 AM
Tig Process ?? millman52 Welding, Brazing, Soldering, Sealing 46 04-30-2007 02:41 PM
machining of polymide coated rollers by hobbing process rvrdom07 General Metalwork Discussion 1 01-22-2007 02:33 AM
