Old 11-05-2009, 04:53 PM
kheri kheri is offline
kheri is on a distinguished road
X and Y Axis designation
Which one is designated as X axis and which one is the Y Axis in a CNC machine ? Is it interchangeable ?
Old 11-05-2009, 05:49 PM
ger21 ger21 is offline
X is typically the longer of the two, but you can set it up any way you want.
Old 11-05-2009, 09:59 PM
Senna's Avatar
Senna Senna is offline
Senna is on a distinguished road
I asked the same question not too long ago and the response was the same as ger21 gave. BUT... if you use Mach3 it designates the axis that moves fore & aft as the Y and the axis that travels left & right as the X as viewed while standing at the front of the machine.
Senna
aka BOOMER52 >>> http://www.rcgroups.com/forums/member.php?u=159693
Old 11-05-2009, 10:17 PM
Mach3 uses a right hand Cartesian coordinate system. Which matches just about all CAD programs out there. It's generally a good idea to have the machine match your CAD program, so parts get cut in the same orientation as you draw them.
Old 11-05-2009, 11:03 PM
Arquibaldo Arquibaldo is offline
Arquibaldo is an unknown quantity at this point
Senna says:
"...designates the axis that moves fore & aft as the Y and the axis that travels left & right as the X as viewed while standing at the front of the machine."
This is perfectly OK, as we all learned in high school... The problem is: What is the front
of the machine? On a lathe or a mill this seems obvious to me, but on a CNC router,
opinions may vary; I think that I am at the front when the Z axis (no question here: this is
the axis parallel to the tool rotation axis) travels from left to right, so that the table (on a
moving table machine) or the gantry (on a moving gantry machine) moves along the Y axis (ie: towards me or away from me), but most people don't seem to think this way...
Nelson
Old 11-06-2009, 07:44 AM
CarveOne CarveOne is online now
CarveOne is on a distinguished road
Originally Posted by Arquibaldo View Post
Senna says:
Nelson
The "front" of the machine is designated by the user in software and can be either the long horizontal axis or the shorter horizontal axis. Most popular rectangular machines are designated by the user as X (the table) being the long axis and Y (the gantry) being the shorter horizontal axis. Z is usually designated as the vertical axis (router).
The so called "wide routers" have the gantry across the longer dimension of the table and the Y as the narrower dimension of the table.
The user has the option of setting up the software in any configuration that they wish to for special purpose CNC machines. As Gerry mentions, it helps the user if the machine is set up to correspond visually with what they see in the CAD software, especially with the solid models. There are less mental gyrations needed by the user when the user is testing the gcode for a 2.5D object that is to be cut.
It all boils down to setting the software up so that it makes sense to you, but if you get gcode from some other source it may move in ways that you don't expect. In that case, you will need to modify the gcode to work correctly with your own machine setup. It's all part of the "fun" of working with CNC control.
CarveOne
"If this thing works, I'll be truly impressed."
Old 11-06-2009, 03:59 PM
Thank you to all you guys for clarifying my inquiry.
Need motor type & designation list for Fanuc 5S motors! John_B Fanuc 3 10-23-2009 05:20 PM
Help understanding a thread designation. danreetz Mechanical Calculations/Engineering Design 2 09-21-2007 04:10 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 03:58 PM
Old carbide grade designation ozzie34231 Composites, Exotic Metals etc 0 03-10-2006 04:12 PM
Thread designation Skillet General Metalwork Discussion 4 10-05-2004 08:59 PM
