Old 11-04-2009, 07:37 PM
Exodus8931 Exodus8931 is offline
Exodus8931 is on a distinguished road
Question Machining Sterling Silver
anyone machined sterling silver before, i'm looking for speeds and feeds to start with,,
i'm going to be using 1/2 endmill for roughing, probably diamond coated, and 1/4 ball for finish, also diamond coated,
i'll look for your input, thanks
Old 11-04-2009, 07:46 PM
sti2011's Avatar
sti2011 sti2011 is online now
sti2011 is on a distinguished road
Can I have the chips?.................I have turned it before but not milled it. If I had to point you in a direction, it is a little like 6063 Alum. soft and gummy. I think that if you treat it that way you'll be good. I'm assuming that you are not milling huge amounts of it and if you are, I definetly want the scrap! Although when you think about it, there are engineered plastics out there that dwarf Gold in cost by weight.
Old 11-05-2009, 03:35 AM
draughted draughted is offline
draughted is on a distinguished road
what are you doing anyway?
please could you look into wax investment casting and save the planet!
Old 11-07-2009, 04:33 AM
Thumbs up
lol, i know, we are going to put in some fine screen mesh, to catch as much as possible, thanks for your info thou, that's what i was figuring, i was going to cut it like 6061 maybe 10% - 20% slower
Old 11-07-2009, 04:37 AM
Cool
i can't say what, it's confidential, but the part is abbout 1" x 1" x 12.25"
can't cast it, too much fine detail on it, they tried, i machined it out of alum and stailess before, so they can see the diffrence between cast and machine,
and its huge,
save which planet, mars ???????????? lol
Old 11-07-2009, 02:00 PM
awerby awerby is offline
awerby is on a distinguished road
I doubt the diamond coating will help much
That's mostly used for cutting abrasive materials like graphite and fiberglass, which wear down the tooling. Sterling mills a lot like aluminum - it's "grabby", but it's a bit harder. I'd experiment with a copper rod to start with; if your speeds and feeds work on copper, they'll work on silver. A cobalt-steel tool will be sharper and less brittle than diamond-coated carbide, not to mention cheaper.
But I also agree with the folks who told you to cast it, not try to carve it out of a solid rod. If you mill it out of wax rod, you can pull a rubber mold from that which will transfer all your detail. Then you can cast a hollow wax, which will cast better than a solid one, while saving a lot of $17/oz silver. Just trying to recycle all that silver swarf is going to be more hassle than not spraying it all over in the first place...
Andrew Werby
www.computersculpture.com
Old 11-08-2009, 09:45 AM
thanks for all the infor form you guys, i don't know y the customer dosent want to have it casted, better for my company i guess, lol,
thanks
silver solder Ti agent141 Welding, Brazing, Soldering, Sealing 2 05-25-2008 09:33 PM
Silver solder temper Australia, New Zealand Club house 11 04-02-2008 06:27 PM
New & Free 1,184-Page Catalog From Stock Drive Products & Sterling Instrument carolpratt Product Announcements & Manufacturer News 0 12-19-2006 02:35 PM
silver and deming, what is it? larrymcdade General Metalwork Discussion 2 10-29-2006 03:24 PM
Silver solder pminmo Welding, Brazing, Soldering, Sealing 11 10-10-2006 11:22 AM
