Old 11-03-2009, 10:13 AM
giveinfo giveinfo is online now
giveinfo is on a distinguished road
My second machine build log (aluminum, Chinese spindle, rails, screws etc.)
I'm building new cnc machine, my second build.
First machine was from MDF (hobby design and all... )
I learned a lot on fist machine and here i will put build log for second machine.
This is construction for second machine.
More pictures you can fine on my site where it will be more detail text and pictures.
www.mycnc.giveinfo.net
Old 11-03-2009, 11:26 AM
contactirfu contactirfu is offline
contactirfu is on a distinguished road
before you proceed the linear rails for the long axis are too low - pls don't do the mistake I have already done.
Old 11-03-2009, 04:23 PM
Why do you think it's low ?*
Old 11-03-2009, 05:21 PM
Hdale85 Hdale85 is offline
Hdale85 is on a distinguished road
Build looks fantastic so far!
Old 11-03-2009, 06:12 PM
Here is more pictures of machine building procces!
ID:	92641   Click image for larger version
ID:	92642   Click image for larger version
ID:	92643   Click image for larger version
Old 11-03-2009, 07:48 PM
Nastyzen Nastyzen is offline
Nastyzen is on a distinguished road
WOW! Your machine is looking very profesional.
I will be following your progress attentivly.I love the ball screw and rail combo .Looks like a rigid setup,you should be able to make acurate parts.
Old 11-03-2009, 08:01 PM
Post
As i started with mdf machine (my first) this one now for me is unbelievable good.
I did little measuring, and on Z axis ( measured with indicator) i can move axis to 1/10 mm (0.1 mm) and 1/100 mm Mach3 and indicator show same number,
Old 11-03-2009, 10:55 PM
I hope you have seen my build - what happens with your and my setup is that as we start inchreasing the height of the gntry the whole thing begins to shudder when there is sudden change of direction.
I am most worried taht you will face the same problem, then ou will have to reduce the speed at which you are running your router.
pls do reconsider and do necessary changes before its too late.
believe me - you will be much happier.
there are a couple of Australian builds you can probably look at - http://www.cnczone.com/forums/showth...t=71219&page=3
RGDS
IRfan
Old 11-06-2009, 12:25 PM
analogman analogman is offline
analogman is on a distinguished road
My datacut machine shutters when I change direction. It has a 80lb gantry, so no wonder why.
http://www.data-cut.com/router.html
All I did was add a few cross braces and adjusted the deceleration/acceleration. The shutter is reduced and does not present an issue. Chris the builder of the original datacut says his shutters and it has not caused any kind of a problem in the 4-5 years he has been running it.
Old 11-16-2009, 06:55 PM
new video
Tags
aluminum extrusion, chinese ballscrews, chinese spindle
New Machine Build- Chinese ballscrews,ballnuts,blocks and rails? kostas1 DIY-CNC Router Table Machines 10 10-04-2009 07:04 AM
Spindle that can machine aluminum Dman65 DIY-CNC Router Table Machines 0 08-03-2009 11:28 PM
Build CNC machine out of aluminum? jeffmorris DIY-CNC Router Table Machines 1 03-24-2008 12:06 PM
Long screws and rails 3Dsigns Linear and Rotary Motion 8 06-14-2007 02:59 PM
Machine Aluminum... Spindle speed and flute count ngr1 General Metalwork Discussion 6 01-04-2005 12:35 AM
