You need to addandCode:loadrt charge_pumpalong withCode:addf charge-pump base-threadto the .hal file for your setup. (Use appropriate pins and parallel port numbers (mine is on the 2nd port thus parport.1...)Code:net charge-pump <= charge-pump.out net charge-pump => parport.1.pin-01-out setp charge-pump.enable 1
