Nice work on this. I used my X2 for a couple years with the crank and cuss method.
Looks nice and solid. I like the angle plate on the column. This is a known weak spot on the X2. Looks like you fixed it on yours.
I received my new mill about 5wks ago and have been building a stand and adding some upgrades. (BTW, in my case, cnc means "crank n cuss")
The stand is an old Kennedy tool box. It was the right price, free. It needed a good cleaning, new paint, one replacement handle and new drawer liners. Made a top from scrap 2x4's and 3/4" plywood to give more height. Don't laugh too much at the color, it was what I had on hand.
The mill is mounted to a 1/2" scrap steel plate and a 9x7x6 angle plate was added to stiffen the Z axis. An air spring kit and a belt drive kit were added to improve performance.(LMS)
Spent most of yesterday tramming and mounting a 3"heavy Kurt clone vise.(LMS) Being a total newbie probably tripled the time involved, but I am very satisfied with the results.
Late last night I finally tried my hand at milling. Took a small piece of 3/8" scrap mild steel and took it down to 1/4" and milled a 1/8" through slot about 1" long. It only took about 20min to make the slot. Most amazing was the fact I didn't break anything with all those RPM's, chiploads, feed speeds, etc running around in my old brain!
Here are some pics.
Thanks for all the input and help.
- FastCut 2" end mill. 4 flutes 7-3/4" OAL, 4" cutting length. 1/2" radius, 79504
- Need Help!- Cutting a 7.1" circle from 0.5" thick 6061 alum - End Mill "loading up"
- Problem- X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
- "NEW" 1/8" 5 FLUTE CARBIDE END MILL "AlTiN"
- Need Help!- "Warco GH Univ" V "Chester Lux Mill"
Mike Broach
Lee
LOL.
I opened this post and began reading. When I got to part about the colour, I scrolled down to see and WOW... Yellow sure is bright
I like the angle plate in the back. Where did you get that angle plate like that?
My X2 is mounted on 3 layers of 3/4 inch MDF that I glued and screwed together to get me two and a quarter inches clearance to turn that Y axis handle.
I like what you did. Effective simple and, need I say, bright...
Been there, done that, got the tee shirt...
The angle plate came from ENCO. It was about $25.
Mike
Mike Broach
That's a very nice looking and practical X2 milling station ncc! You have solved most of the X2 weaknesses. When you get tired of cnc and decide to go for CNC--It will be relatively easy to plug in a G540, some steppers and a computer and GO! The top drawer of the tool chest is perfect for the keyboard.
I incorporated a tool chest into my X3 work station. I also use one as a dual mini-lathe station. Did you leave the wheels on that tool chest? If so do you notice any undue motion during milling?
CR.
Do you happen to remember which one you got from ENCO, there a few of them at http://www.use-enco.com/CGI/INPDFF?P...MITEM=418-4330 and I like to get the one you got (with the slots in it.)
Thanks!
Here you go:
http://www.use-enco.com/CGI/INSRIT?PMAKA=418-4540
CR.
Spaceballs, that's the one.
Crevice, I left the wheels on. My shop is small and all of my major work stations have wheels, ie:floor model drill press, table saw,horrizontal metal saw,grinder table. The mill is rock solid with all of the mass. Lot's of stuff stored in the old Kennedy.
Mike Broach
nc-
have you tried to do any precise milling with the machine? if you have, what kind of tolerances are you getting from it?
-Jeff
Jeff, I haven't tried any precison work yet. Still just playing and learning.
I am going to check the tram again this weekend, just to see how it's holding up.
Mike Broach
free shipping code for Enco orders over $50 good till june 5th
FSAPR4
I did have quite a bit of backlash on my X2, but if it's not cnc'ed, it really is a minor issue. It was plenty accturate to cut some small steel and aluminum parts. I only saw the column flex issue when I cut too deep anyway.
I actually used a power feed of sorts on mine. I just used an 18V cordless drill to turn the nuts on the handles. This kept my arms from getting any more Popeye like than they are already and made short work of some jobs.
Lee
Jeff, what kind of accuracy are you looking for? A lot of variables come into play with any machining ie. tooling,technique,material and the inherent accuracy of the machine. The weakest part of the mini mill is the Z axis stiffness.This can be greatly improved by various means. Lots of ways to skin this cat at a moderate cost. Backlash is something you can work with in manual milling. If you are looking for a mill that is ready to go right out of the box, you will have to spend a lot more $$$$.
Mike Broach
Honestly, I don't know yet. I'm still doing my design. I am thinking it will have to be between 1/100th and 1/1000th, but again I still designing my robot. This what it looks like (http://www.cnczone.com/gallery/showp...der/perpage/12).
It is 16mm around. The materials I am planning on working with are aluminum, UHMW, unistrut, and some steel.
In terms of technique, I have done a lot of woodworking, but I am still learning about metal working.
I was leaning more toward to an X3 or getting an X4+ from syil when they are available here in the US.
-Jeff
I don't think the X2 would suit your needs.
Mike Broach
