I had to scrape a set of set precise ballnuts into a set of mounts here at work a few years ago and I used a sanding disc instead of a scraper - primarily due to convenience and time.
In my opinion it is the same priniciple - manually removing small amounts of material to achieve the desired results.
No flames from me....
Scott
