What limits are you refering to?
As it cuts ok when insulated from the bed, then it would not appear to be a loading problem etc.
What type of router head do you have?
It sounds like you are getting some kind of leakage from the router to ground, if so this may be producing spurious signal into your drives.
Is the router feed 2 wire or three wire (have a ground wire)?
