Not in the g-code. You can, though, create M code macros with if..then and while... loops and call them from the g-code. A bit more trouble, but it is doable.
Hi All,
I am pretty new to CNC and I am actually learning this stuff to help my father.
I have used EMC2 a little bit and like it much better than the Kcam he started with.
With EMC2 I can use conditional statements and while loops in my gCode using "O" words. I tried this with Mach3 trial version to no avail. Does the paid version of Mach3 Support looping and conditions. I did find in the manual the use of macros as subroutines. But no mention of conditional or looping statements.
Thanks for your response.
UCCNC 2017 Screenset
Can you give me an example? I know how to use M98/99 for macros but how do I use a macro for conditional and looping statements in Mach3.
We are looking into purchasing Mach 3 with the mill add-ons. I like the fact that I can write VB extensions for it much like I write extensions for EMC2 using Php, C++, and Python. However, much of what my Dad is doing is easier done with loops and once in a while I find conditional statements to be handy.
I can already tell Mach 3 is much better than KCam. I like EMC2 and it seems very powerful. But Dad can't see the screen very well and I don't have time to write a new UI for it right now. So Mach 3 seems to be the easiest route right now. It looks comparable to EMC2 as far as I can tell. What is your take on Mach 3 For beginners?
Thank you again for your help.
You can use VB script in the macro, and assign it to any M code, like M555. When you call the M555 in your g-code, it'll run your VB script.
Here's a lot of samples.
http://www.machsupport.com/forum/ind...oard,75.0.html
Mach3 for beginners? The main problem is that there's too much stuff on the screens that most beginners don't need. I use a greatly simplified screen that I made.
http://www.machsupport.com/forum/ind...c,11115.0.html
Other than that, it's very easy to use.
Ok, I get it. I have to do it in VB and pass in the arguments from the gcode. That's kind of an odd solution. I would have thought that a program that looks as advanced as Mach3 would have support for loops and conditionals.
Thank you for the info. You have been a great help!
http://www.youtube.com/user/vlmarshall
