Cut out the Anti Backlash Nut Assembly, here is a picture on CNC Machine and a Finished Assembly.
What i do is see the parts that is most available and easy to get then build a machine around that. For example the standard lengths and standard thread and pipe dia.Originally Posted by Kammo1
Motor / Lead Screw coupler.....
Here are the Large Adjustment Blocks.....
Large Adjustment Blocks Installed...
Added two springs tothe Z Axis to act as a counter balance so the motor does not have to work as hard to lift the tool.
Looks great Joe,
The springs are an original idea.
I am also starting the build of my second machine. It will look alot like yours I think. I have finished manufacturing the parts out of nylon and bought my sheet of 3/4 MDF today. I am planning how to cut all the pieces out of the 4'X8' sheet. My first machine was the JRGO and my second will be a decendent thereof. Keep the pics coming!!!!
Greg
I will see once it is finished, if so i can add a suport on the interior of the pipes.Originally Posted by ger21
Got the Bottom Section complete, not just need to put it all together, Here is a picture of it, and also a picture to see the Size comparison to my 1st machine.
